Visitor sysseon
Xilinx SDK - Error building BSP
I'm sorry if that's a stupid question, but I'm stuck. I'm working with Xilinx SDK, but yesterday it suddenly started giving errors while building my projects. The problem seem to be related to BSP built. After looking for a solution with no luck, I decided to uninstall Vivado + Xilinx SDK and in passing I upgraded to 2014.2 version, but still no luck. Suggestions?
That is the error:
make: *** [ps7_cortexa9_0/libsrc/...........] Error 5
Thank you so much.
Sysseon
Visitor sysseon
Re: Xilinx SDK - Error building BSP
Thanks Norman. Yes, it was a Temp directory problem, more precisely a privileges problem.
I found the answer in the Microsoft Community forum. I hope is not a problem to paste it here (my English is not very good, so it would take a time for me to explain).
" Answer by Moogles:
The problem is with the security permissions on your profile temp folder. To fix it navigate to %temp% or C:\Users\[Username]\AppData\Local and right click on the Temp folder and choose properties, then click the security tab and click advanced.
On the permissions tab you should see the permissions that are there. There should 3 which are:
'SYSTEM' with Full control which applies to 'This folder, subfolders and files'
'Administrators' with Full control which applies to 'This folder, subfolders and files'
'Your Username' with Full control which applies to 'This folder, subfolders and files'
and all 3 should be inherited from the C:\Users\[Username]\ folder.
If you don't have the 'Include inheritable permissions from this object's parent' option ticked, then tick it and click continue if there are any problems, then remove the permissions that aren't inherited.
Once you click 'Apply' and click 'OK' you should have the permissions to write to the directory and you won't get those error messages any more."
So, problem solved! Thank you for your help!
Sysseon
Is this a BSP that is being updated or built from scratch?
Would that be possible to attach the bsp.log?
--Hem
Visitor sysseon
The problem appeared when I was working with a project that used that BSP, but I didn't modified it. After that, I've created new BSPs from scratch, but the problem persists. As I said, I even reinstalled all software.
I attach the bsp.log. Thank you for the help!
I have seen a similar issue in 2014.1.
Can you try Inserting a line "set LIB=" at the top of the XSDK.bat file?
The XSDK.bat file is available in the install location SDK\2014.2\bin
Close SDK and reopen it once the changes are made.
Please let me know if this helps.
Achutha
Visitor sysseon
Thanks for the help, but the problem persists. I attach my 'xsdk.bat' in case it could be the source of the errors. Now I have only 2014.2 version installed. However, before that, I had the same error with 2013.3 and 2014.1 (both of them installed, but the problem appeared when working with 2014.1).
Thanks again.
Sysseon
Scholar norman_wong
The error in your bsp.log is:
process_begin: CreateProcess(C:\Users\Noessys\AppData\Local\Temp\make5580-1.bat, C:\Users\Noessys\AppData\Local\Temp\make5580-1.bat, ...) failed.
make (e=5): Acceso denegado.
In English:
make (e=5): Access is denied.
A bit of Google and most sites would suggest you have multiple "makes" with your PATH. I think you are invoking a "make" with no privilege. Try the windows command "where" (equivalent to linux "which):
where *make*.*
Visitor sysseon
Ok, thanks. I've googled, but I don't understand which "make" I should use. If I execute command
where *make*.*
I get
C:\Windows\System32\makecab.exe
Is that correct? Should I remove any path from my PATH environment variable? I'm very sorry to be boring, but I've never understood this compilers issue.
Thanks again.
Scholar norman_wong
I spoke too soon on the "where" command. I got the same results. I think Xilinx SDK sets up it's own paths inside it's own command shells. A quick search of the my Xilinx directory gives only 2:
14.7\ISE_DS\EDK\gnu\MinGW\Beta\nt64\bin\make.exe
14.7\ISE_DS\EDK\gnu\gnuwin\bin\make.exe
No idea which one is used. Eclipse and Xilinx do hide details. My bsp.log looks nothing like yours. I assume 2014.2 Vivado is much different than 14.7 ISE. No XDSK.BAT her either. Sorry about that. Red herring.
Visitor sysseon
In my Xilinx directory there are only two makes:
C:\Xilinx\SDK\2014.2\gnu\arm\nt\bin\cs-make.exe
C:\Xilinx\SDK\2014.2\gnuwin\bin\make.exe
In case one of them is the correct make for Xilinx SDK, how could I do Xilinx to use it? If that is a privileges issue, how could I fix it? I'm sorry, but I'm really stuck these days with this problem...
Thank you.
Sysseon
Scholar norman_wong
A bit more Googling and reading and I would guess that it is not "make" but what "make" is trying to start. In your attached bsp log, something is objecting to this file.
Perhaps try a closing all apps and emptying the Temp directory.
Visitor sysseon
Sysseon
Scholar norman_wong
That's good news. Thanks for posting your solution. This will come in handy if I or others encounter the same problem. Makes me wonder how the permissions got changed in the first place.
Please mark your post as solved.
Hello All,
I'm going through the Zybno tutorial, lab1.
http://www.xilinx.com/support/university/vivado/vivado-workshops/Vivado-embedded-design-flow-zynq.html
When I move on to the SDK section I get the following error when building the bsp.
make: *** [ps7_cortexa9_0/libsrc/coresightps_dcc_v1_2/src/make.libs] Error 2    mem_test_bsp
I'm not editing anything. The OS is Centos 7.2. Vivado 2015.4(64-bit) I tried the methods mentioned above but got the following response
sudo yum install libselinux1:i386
[sudo] password for <username>:
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
 * base: mirror.5ninesolutions.com
 * epel: mirror.unl.edu
 * extras: mirror.5ninesolutions.com
 * updates: mirror.5ninesolutions.com
No package libselinux1:i386 available.
Error: Nothing to do
Where are we supporsed to edit the path? In the Makefile? or the system's $PATH? I'm attaching the Makefile from my mem_test_bps folder.
I didn't get any errors or warnings while installing.
Any suggestions?
Thank you,
Sudhanshu
I figured it out.
I'm using Centos 7.2 so there seems to be a library issue.
Solution is
sudo yum install libselinux.i686
You may later face the issue of the programming cable not working so just try
sudo -s
source /opt/Xilinx/SDK/2015.4/data/xicom/cable_drivers/lin64/install_script/install_drivers/install_digilent.sh
Last step is in case you are using Zybo RevB like me.
