Xilinx Uart 16550
I have a Microblaze system with an Xilinx Uart 16550 connected. The uart is setup with FIFO enabled and 8 byte of threshold.
Reading the manual of uart I expect an ISR when 8 byte has received into the FIFO but this don't happening, I have an ISR at every byte received.
The configuration code of uart is:
	XUartNs550_SetBaudRate(UartInstancePtr,baudrate);
	XUartNs550_WriteReg(UartInstancePtr->BaseAddress,XUN_MCR_OFFSET,0x02);			//XUN_MCR_RTS
	XUartNs550_WriteReg(UartInstancePtr->BaseAddress,XUN_LCR_OFFSET,0x03);			//XUN_LCR_8_DATA_BITS & ~XUN_LCR_LENGTH_MASK & ~XUN_LCR_ENABLE_PARITY
	XUartNs550_WriteReg(UartInstancePtr->BaseAddress,XUN_IER_OFFSET,0x01);			//XUN_IER_RX_DATA
	XUartNs550_WriteReg(UartInstancePtr->BaseAddress,XUN_FCR_OFFSET,0x47);			//XUN_FIFO_TRIGGER_08 | XUN_FIFO_ENABLE | XUN_FIFO_RX_RESET | XUN_FIFO_TX_RESET
Can anyone help me?
Re: Xilinx Uart 16550
c,
Nowhere do I see a feature to provide an interrupt when the FIFO has 8 characters described in the manual.
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks for the reply.
I have solved the problem!
hi,
can you mark this post as solved and also let us know how this problem was solved. this will help out other users
--hs
