Visitor debosteebo
Xilkernel Lwip Issues after initializing large number of semaphores (118)
I would like to know if anyone has experienced or have recommendations on how to debug the following issue with Xilkernel + LWIP + ML605.
When implementing in Xilkernel, I hit a consistent issue where LWIP's accept and/or select routines will start to crash when after approximately 118 semaphores have been ininitialized.  I have verified my Xilkernel BSP settings that I am familiar with are set correctly to set this number of semaphores (config_sema max_sem=130, max_sem_waitq=130).  Furthermore, altering the runtime heap and stack sizes does not appear to play a role as increasing/decreasing these sizes doesnt change the consistency of the issue.  I have gone to the point where I have essentially commented out all my code execept for a single thread which initializes 118 semaphores and basic lwip routines.  There are two flavors of of lwip crash observations.  One is that lwip_select will immediately unblock with "timeout" even if set to "forever block" or a set number block.  The other observation is that lwip_accept will return a negative descriptor upon client connection with no errno indication.  Just to reiterate, note that these issues are nonexistent if there are "117" or less semaphores related.  Any idea of what I should check next?
 PARAMETER VERSION = 2.2.0
BEGIN OS
 PARAMETER OS_NAME = xilkernel
 PARAMETER OS_VER = 5.01.a
 PARAMETER PROC_INSTANCE = mb
 PARAMETER STDIN = Console_Uart
 PARAMETER STDOUT = Console_Uart
 PARAMETER SYSTMR_SPEC = true
 PARAMETER SYSTMR_DEV = timer
 PARAMETER SYSINTC_SPEC = int_ctl
 PARAMETER CONFIG_SEMA = true
 PARAMETER CONFIG_MSGQ = true
 PARAMETER USE_MALLOC = true
 PARAMETER MAX_PTHREADS = 25
 PARAMETER PTHREAD_STACK_SIZE = 32768
 PARAMETER CONFIG_PTHREAD_MUTEX = true
 PARAMETER MAX_PTHREAD_MUTEX = 50
 PARAMETER MAX_PTHREAD_MUTEX_WAITQ = 20
 PARAMETER MAX_SEM = 130
 PARAMETER MAX_SEM_WAITQ = 130
 PARAMETER CONFIG_TIME = true
 PARAMETER MAX_READYQ = 20
 PARAMETER MAX_TMRS = 50
 PARAMETER ENHANCED_FEATURES = true
 PARAMETER CONFIG_YIELD = true
 PARAMETER NUM_MSGQS = 30
 PARAMETER STATIC_PTHREAD_TABLE = ((main_thread,1))
END
BEGIN PROCESSOR
 PARAMETER DRIVER_NAME = cpu
 PARAMETER DRIVER_VER = 1.13.a
 PARAMETER HW_INSTANCE = mb
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = uartlite
 PARAMETER DRIVER_VER = 2.00.a
 PARAMETER HW_INSTANCE = Console_Uart
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = v6_ddrx
 PARAMETER HW_INSTANCE = DDR3_SDRAM
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = gpio
 PARAMETER DRIVER_VER = 3.00.a
 PARAMETER HW_INSTANCE = DIP_Switches_8Bits
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = axiethernet
 PARAMETER HW_INSTANCE = ETHERNET
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = axidma
 PARAMETER DRIVER_VER = 5.00.a
 PARAMETER HW_INSTANCE = ETHERNET_dma
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = FMC_GPIO
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = HSADC_GPIO
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = iic
 PARAMETER DRIVER_VER = 2.04.a
 PARAMETER HW_INSTANCE = IIC_EEPROM
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = LEDs_8Bits
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = LEDs_Positions
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = Push_Buttons_5Bits
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = spi
 PARAMETER DRIVER_VER = 3.03.a
 PARAMETER HW_INSTANCE = SPI_HS_ADCS
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = SPI_RX_A
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = SPI_RX_B
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = generic
 PARAMETER DRIVER_VER = 1.00.a
 PARAMETER HW_INSTANCE = clk_tst_0
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = debug_module
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = intc
 PARAMETER DRIVER_VER = 2.03.a
 PARAMETER HW_INSTANCE = int_ctl
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = bram
 PARAMETER HW_INSTANCE = mb_d_bram_ctrl
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = mb_i_bram_ctrl
END
BEGIN DRIVER
 PARAMETER HW_INSTANCE = sigconx_if_0
END
BEGIN DRIVER
 PARAMETER DRIVER_NAME = tmrctr
 PARAMETER HW_INSTANCE = timer
END
BEGIN LIBRARY
 PARAMETER LIBRARY_NAME = lwip140
 PARAMETER LIBRARY_VER = 1.00.a
 PARAMETER API_MODE = SOCKET_API
END
_STACK_SIZE = DEFINED(_STACK_SIZE) ? _STACK_SIZE : 0x40000;
_HEAP_SIZE = DEFINED(_HEAP_SIZE) ? _HEAP_SIZE : 0x40000;
/* Define Memories in the system */
MEMORY
   mb_i_bram_ctrl_mb_d_bram_ctrl : ORIGIN = 0x00000050, LENGTH = 0x0003FFB0
   DDR3_SDRAM_S_AXI_BASEADDR : ORIGIN = 0xA4000000, LENGTH = 0x04000000
/* Specify the default entry point to the program */
ENTRY(_start)
/* Define the sections, and where they are mapped in memory */
SECTIONS
.vectors.reset 0x00000000 : {
   *(.vectors.reset)
.vectors.sw_exception 0x00000008 : {
   *(.vectors.sw_exception)
.vectors.interrupt 0x00000010 : {
   *(.vectors.interrupt)
.vectors.hw_exception 0x00000020 : {
   *(.vectors.hw_exception)
.text : {
   *(.text)
   *(.text.*)
   *(.gnu.linkonce.t.*)
} > DDR3_SDRAM_S_AXI_BASEADDR
.init : {
   KEEP (*(.init))
.fini : {
   KEEP (*(.fini))
.ctors : {
   __CTOR_LIST__ = .;
   ___CTORS_LIST___ = .;
   KEEP (*crtbegin.o(.ctors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors))
   KEEP (*(SORT(.ctors.*)))
   KEEP (*(.ctors))
   __CTOR_END__ = .;
   ___CTORS_END___ = .;
.dtors : {
   __DTOR_LIST__ = .;
   ___DTORS_LIST___ = .;
   KEEP (*crtbegin.o(.dtors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors))
   KEEP (*(SORT(.dtors.*)))
   KEEP (*(.dtors))
   __DTOR_END__ = .;
   ___DTORS_END___ = .;
.rodata : {
   __rodata_start = .;
   *(.rodata)
   *(.rodata.*)
   *(.gnu.linkonce.r.*)
   __rodata_end = .;
.sdata2 : {
   . = ALIGN(8);
   __sdata2_start = .;
   *(.sdata2)
   *(.sdata2.*)
   *(.gnu.linkonce.s2.*)
   . = ALIGN(8);
   __sdata2_end = .;
.sbss2 : {
   __sbss2_start = .;
   *(.sbss2)
   *(.sbss2.*)
   *(.gnu.linkonce.sb2.*)
   __sbss2_end = .;
.data : {
   . = ALIGN(4);
   __data_start = .;
   *(.data)
   *(.data.*)
   *(.gnu.linkonce.d.*)
   __data_end = .;
.got : {
   *(.got)
.got1 : {
   *(.got1)
.got2 : {
   *(.got2)
.eh_frame : {
   *(.eh_frame)
.jcr : {
   *(.jcr)
.gcc_except_table : {
   *(.gcc_except_table)
.sdata : {
   . = ALIGN(8);
   __sdata_start = .;
   *(.sdata)
   *(.sdata.*)
   *(.gnu.linkonce.s.*)
   __sdata_end = .;
.sbss : {
   . = ALIGN(4);
   __sbss_start = .;
   *(.sbss)
   *(.sbss.*)
   *(.gnu.linkonce.sb.*)
   . = ALIGN(8);
   __sbss_end = .;
.tdata : {
   __tdata_start = .;
   *(.tdata)
   *(.tdata.*)
   *(.gnu.linkonce.td.*)
   __tdata_end = .;
.tbss : {
   __tbss_start = .;
   *(.tbss)
   *(.tbss.*)
   *(.gnu.linkonce.tb.*)
   __tbss_end = .;
.bss : {
   . = ALIGN(4);
   __bss_start = .;
   *(.bss)
   *(.bss.*)
   *(.gnu.linkonce.b.*)
   *(COMMON)
   . = ALIGN(4);
   __bss_end = .;
_SDA_BASE_ = __sdata_start + ((__sbss_end - __sdata_start) / 2 );
_SDA2_BASE_ = __sdata2_start + ((__sbss2_end - __sdata2_start) / 2 );
/* Generate Stack and Heap definitions */
.heap : {
   . = ALIGN(8);
   _heap = .;
   _heap_start = .;
   . += _HEAP_SIZE;
   _heap_end = .;
.stack : {
   _stack_end = .;
   . += _STACK_SIZE;
   . = ALIGN(8);
   _stack = .;
   __stack = _stack;
_end = .;
