Observer engll
ZC706 does not configure from Flash upon power up
I am not able to configure the 7Z045  on ZC706 from the Flash upon power up.  I am listing the steps I took below.  Any help and suggestions are much appreciated.
1. The design was done in Vivado 2014.4 on Ubuntu and both PS and PL come up using JTAG for configuration.
2. The FSBL is done in SDK to get an appboot.elf file.
3. The QSPI is added using "Program Configuration Memory Device" in Vivado Hardware Manager.
4. The QSPI is programmed using HW Mgr with the design bit file and appboot.elf as FSBL.
5. The device specified is "s25fl128s-1.8v-qspi-x4-dual_stacked".
6. Flash is programmed successfully without any error message in HW Mgr.
7. Set SW11 on ZC706 to 00010 to boot from flash.
8. Power cycle the board, but the DONE LED never comes up.
Observer engll
Re: ZC706 does not configure from Flash upon power up
I restored the Flash content per xtp247 and it works fine.  Going over the files in xtp247 led me to locate the problem - the wrong elf file was specified as the FSBL file.   Once that is corrected, my design comes up as expected.
Thanks to everyone who responded and helped!
hi,
can you try to restore the flash contents as mentioned in this pdf?
http://www.xilinx.com/support/documentation/boards_and_kits/zc706/2014_3/xtp247-zc706-restoring-flash-c-2014-3.pdf
--hem
Scholar sampatd
Can you check with the ZC706 BIST design if you are able to boot from the QSPI flash?
What is the spi clock frequency? Can you reduce it and check if you are able to boot?
Yes, as @sampatd said try BIST design FLASH application.
Refer to http://www.xilinx.com/support/documentation/boards_and_kits/zc706/2014_4/xtp242-zc706-bist-c-2014-4.pdf .
Praveen
Check the ZC706 debug checklist and see if the switch and jumper settings are set to default - http://www.xilinx.com/support/answers/54013.html
Anirudh
Observer engll
