Zybo Z7 I2C example failing
I am trying to configure my audio codec on Zybo board using I2C.
I am using I2C from ZYNQ PS. When I run xiips_master_polled_example, it fails.
I haven't change anything within example besides the address of device (I put address of the codec from the datasheet of Zybo board).
Can anyone say what might be a problem?
Hello @mmesan,
please debug the program, and let us know at which point if fails?
\Razi
-- Don’t forget to Reply, Kudo, and Accept as Solution --
@mmesan,
Please understand that everyone here is aware of the Zybo and the failing codec example you are talking about.
That is why you have to be very specific. What exactly is failing?
Another advise is that you can start a question (again please be specific with all background info and your failure details) inside the Digilent forum. As it is their example design so you have a change to get better/faster solution.
FPGA enthusiast!
All PMs will be ignored
