Zynq 7020 Production Chip, JTAG chain does not show the DAP.
Hello,everyone!
I have a problem on the Zynq 7020 production chip.
Why JTAG chain does not show the DAP? Where ARM?
iMPAC:
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: 41.52 C, Min. Reading: 34.13 C, Max. Reading: 42.01 C
1: VCCINT Supply: Current Reading: 1.005 V, Min. Reading: 1.005 V, Max. Reading: 1.011 V
1: VCCAUX Supply: Current Reading: 1.813 V, Min. Reading: 1.808 V, Max. Reading: 1.816 V
'1': Reading status register contents...
[0] CRC ERROR : 0
[1] DECRYPTOR ENABLE : 0
[2] PLL LOCK STATUS : 1
[3] DCI MATCH STATUS : 1
[4] END OF STARTUP (EOS) STATUS : 0
[5] GTS_CFG_B STATUS : 0
[6] GWE STATUS : 0
[7] GHIGH STATUS : 0
[8] RESERVED : 1
[9] RESERVED : 1
[10] RESERVED : 1
[11] INIT_B INTERNAL SIGNAL STATUS : 1
[12] INIT_B PIN : 1
[13] DONE INTERNAL SIGNAL STATUS : 0
[14] DONE PIN : 0
[15] IDCODE ERROR : 0
[16] SECURITY ERROR : 0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS : 0
[18] CFG STARTUP STATE MACHINE PHASE : 0
[19] CFG STARTUP STATE MACHINE PHASE : 0
[20] CFG STARTUP STATE MACHINE PHASE : 0
[21] RESERVED : 0
[22] RESERVED : 0
[23] RESERVED : 0
[24] RESERVED : 0
[25] RESERVED : 1
[26] RESERVED : 1
[27] HMAC ERROR : 0
[28] PUDC_B PIN : 0
[29] BAD PACKET ERROR : 0
[30] CFGBVS PIN : 1
[31] RESERVED : 0
I also encountered such problem on our own designed board. The solution may be to disable the "PLL Bypassed" as discussed in this link http://www.xilinx.com/support/answers/54195.html
Thanks, it worked.
Hi, I am having the same problem with JTAG chain not showing the DAP, did you disable the PLL by setting MIO6 high?
Thanks!
INFO:iMPACT - Current time: 04/25/2014 4:47:32 PM
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
1: Device Temperature: Current Reading: 38.56 C, Min. Reading: 31.18 C, Max. Reading: 39.55 C
1: VCCINT Supply: Current Reading: 1.008 V, Min. Reading: 1.005 V, Max. Reading: 1.008 V
1: VCCAUX Supply: Current Reading: 1.796 V, Min. Reading: 1.793 V, Max. Reading: 1.796 V
[0] CRC ERROR : 0
[6] GWE STATUS : 0
[8] RESERVED : 1
[9] RESERVED : 1
[10] RESERVED : 1
[12] INIT_B PIN : 1
[14] DONE PIN : 0
[21] RESERVED : 0
[22] RESERVED : 0
[23] RESERVED : 0
[24] RESERVED : 0
[25] RESERVED : 1
[26] RESERVED : 1
[27] HMAC ERROR : 0
[28] PUDC_B PIN : 1
[30] CFGBVS PIN : 1
[31] RESERVED : 0
XC7Z010 work in Cascaded JTAG mode, JTAG chain does not show the ARM DAP, SOS,t
@aav_nppntt wrote:
Thanks, it worked.
hanks for reply!
