michelcharette
Zynq: how to use register DRAM_param_reg4 to access a lpDDR2 configuration
I'm trying to access a lpDDR2's IC's Mode Registers and that normally would go through the Zynq's DRAM_param_reg4 register. Does anyone have an example on how to use this register?
AR# 47582 (https://www.xilinx.com/support/answers/47582.html) refers to this register without explanation.
The documentation (ug585) for the register's fields is confusing:
  • reg_ddrc_mr_rdata_valid: This bit indicates whether the Mode Register Read Data present at address 0xA9 is valid or not.
    • Q: where does the 0xA9 come from? Sounds like a magic number pulled from another document without reference
  • reg_ddrc_mr_data: LPDDR2: The 16 bits are interpreted for reads and writes: (...) Writes: MR Addr[7:0], MR Data[7:0].
    • The bits 7:0 seem to hold both address and data and nothing in bits 15:8...
yzhang
MR register runtime access method is not provided. You can change the mode registers value during initialization in ps7_init.c. The related register is DRAM_param_reg4, DRAM_EMR_reg and DRAM_EMR_reg. Below article is an example to change ODT with mode register.
https://www.xilinx.com/support/answers/51744.html
