shweta_agnihotri
bsp creating problem in v2014.4 sdk
sir
in v2014.4 after importing hardware file in SDK , it is not allowing to make BSP file.
and showing error : BSP is not generating , see SDK run log file....
thanks
shweta
space appplication center
ahmedabad
htsvn
hi,
the SDK.log is not attached. Also can you attach the xml/hdf of your design?
--hs
shweta_agnihotri
sri
 plz reply my query. I have also attached sdk log file and hdf file , but no solution received since then.
thanks and regard
shweta
apace applicaton center
ahmedabad
thanks
shweta
ahmedabad
htsvn
hi
the files are not attached for further debug.
can you attach them again?
--hs
shweta_agnihotri
sir
I am attaching files again.
thanks
shweta
ahmedabad
htsvn
hi,
this is not the xml i am looking for. when you export the hardware to SDK, there will be a HDF/XML file generated.
can you share that?
Also share the bd.tcl file of your project.
--hs
shweta_agnihotri
sir
I am attaching files.. which hdf file u r looking for ....
there are  2 files generating ..... when I export the hardware .. I am attaching both
1-- SDK / kc705_fmc150.hdf
2--- hwplatform_0 / system.hdf
it is giving the following error while attaching documents
Correct the highlighted errors and try again.
  • The attachment's design_1_bd.tcl content type (text/plain) does not match its file extension and has been removed.
    The attachment's KC705_fmc150.hdf content type (application/x-zip-compressed) does not match its file extension and has been removed.
    The attachment's system.hdf content type (application/x-zip-compressed) does not match its file extension and has been removed
thanks
shweta
ahmedabad
