calculation of execution time of a thread in XILKERNEL
hiee
I am using spartan3e and i have successfully implemented xilkernel in my board and able to run a static thread,,
Do u all have any idea that how could i calculate the time of execution of my thread as we usually use XPS_TIMER in our design with xilkernel....
thank you
regards
Joy
Advisor
Advisor
Re: calculation of execution time of a thread in XILKERNEL
Hi Joy,
One simple but fairly accurate technique is to instument your thread to toggle an IO by writing to a register (for example toggle an IO every time you enter a thread). This can be an external FPGA IO that you can monitor with a logic analyzer, or virtual IO that hooked up to the ChipScope ILA core.
Evgeni
Just use an XPS_TIMER then?  If you haven't got a spare one, add one - that's the beauty of an FPGA-based system :)
Alternatively, when I needed better precision than the XPS_TIMER I created a small DWFSL perpiheral which logged a timestamp each time it was written to.  These timestamps were stuffed into the returning FIFO-d FSL, and read once per algorithm iteration.  The software then did some calculations to show me min/ave/max timing for various sections of code. (The advantage of using the FSL is that it gives very low-jitter - due to no bus accesses.)
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
Thanx for reply.......usually axilkernel code outline is
#include “stdio.h”
#include "xmk.h"        // Xilinx Micro Kernel library
int main(void)
xilkernel_main();   /* Start the kernel */
/* Control does not reach here */
void* main_thread(void)     /* Statically created first thread */
xil_printf("This is thread \r\n");
return NULL;
where should use what sort of function to measure execution time of my thread by XPS_TIMER...
#include “xmk.h
#include <stdio.h>
#include “xmk.h
#include <stdio.h>
/* various declarations and definitions go here */
int main()
/* Application initialization code goes here */
/* Don’t invoke kernel interfaces yet */
xilkernel_main (); /* Start the kernel */
#include “xmk.h
#include <stdio.h>
int main()
#include “xmk.h
#include <stdio.h>
int main()
Read the timer at the start of your thread, read it again at the end.  Subtract the two. Divide by the clock rate.
Obviously if you have more than one thread running and/or interrupts going off, the timing will vary from run to run, even for a very simple thread, but that's life in the real world.
* If you need hard deterministic tick-level performance for something simple, do it in hardware.
* If you can live with no particular guarantees about worst-case behaviour, carry on.
* If you do need hard real-time performance, but hardware is inappropriate, you'll have to join the "real-time embedded systems" world, do lots of analysis and likely make the some carefully thought-out financial invesments in tools
Martin Thompson
Thanx for ur ans
would u plz explain what the changes should be made for appropiate hardware for "real-time embedded systems" world...
do u have any idea that how further we could work with RTOS in FPGA
domain and what kind of hardware changes should be made for real time
systems
plz share
regards
Joy
That's a massively application specific question, there's just too many things to consider. You're either going to have to "learn by doing" as you go, or engage with someone who's been doing it for years to help you up the learning curve. It's not something which can be sorted in a few newsboard messages I'm afraid! Martin
Martin Thompson
Ok
atlast i was able to measure the time of a thread.using XPS_TIMER including "xtmrctr.h"..by setting a timer before and after execution of that thread
the time taken to execute a algorithm in a thread is comparitevely very low while the algo was running in general without xilkernel...
what could be the reason that faster the execution in a thread, the clock and processor are same in both program:smileyindifferent::smileyindifferent:
First guess would be caches - were they enabled for both versions?
Martin Thompson
yes that was enabled in both program..
while i am executing a algo in  a function and executing in a thread i think that differs....
Can you post your timing code?  How are you detecting that the thread has finished?
Martin Thompson
I have added only one thread with priority 1 in xilkernel setting at Pthread_static_function ie start_func my code is this type
#include"xmk.h"
#include"stdio.h"
#include"xtmrctr.h"
void Start_Timer()
//fuction
int Stop_Timer()
int Get_Timer()
return...
int main(void)
Start_Timer();
start_timer_value=Get_Timer();
xilkernel_main();
void* start_func ()   /*staic thread*/
///algo starts
    end_timer_value=Stop_Timer();
xil_printf("\n\rStart Timer Value=> %d\n\r",start_timer_value);
xil_printf("\n\rEnd Timer Value=> %d\n\r",end_timer_value);
/// algo output
       I have only one thread and want to stop my timer when my algo ends...similarly i had started my timer at begining of my algo and ended at that same place in my genaral program without using xilkernel
regards
Joy
Hmmm. Assuming you are timing the "non-xilkernel" algorithm is much the same way, there doesn't look to be a problem there.
Other places to look:
* linker file - is some data or code located differently in one project or the other?
* Run it lots of times in each project - is the algorithm time actually varying a lot, and it just *looks* like the project settings are different?
* Compiler optimisation settings
* Debug settings
* Caches (I think I already said this)
* compare the other compiler flags (eg is the slow project using software floating-point for some bizarre reason?)
I'll post more if I think of them!
Martin Thompson
