Observer torokb
canps driver problem
Hello everyone!
I work with Xilinx SDK 2016.3. This environment offers canps_v3_1 driver for the can bus peripherals of the zynq-7000 devices. The previous version of this driver (canps_v3_0) worked well, but now I am stucked. The difference is in the source file "xcanps.c". There is an undocumented change in the function: XCanPs_Send, about some endianness of the frame data. Lines 495 and 497.
Has anyone information about this change??
Re: canps driver problem
It has been reported to update in change log of  driver abourt "Xil_EndianSwap32 - 32 bit conversion" .
Praveen
Xil_EndianSwap32 - 32 bit conversion is applied on reading the DW1 and DW2 of CAN.
Could you let us know what exactly is not working and which version of tool are using?
Praveen
Observer torokb
The version of the can_ps driver is in my first post. I am using SDK 2016.3
In my project, I use a zynq device to communicate with a third party PLC over CAN bus. The communication failed with the new version of the can_ps driver. The problem is worked around by now, but I can not see why this "Xil_EndianSwap32 - 32 bit conversion" is undocumented in the change log of the device driver.
Praveen
Observer torokb
Thank you!
