Observer haichithunta
compilation error
**** Full rebuild of configuration Debug for project ledt ****
make clean all
rm -rf main.o  main.d  ledt.elf
powerpc-eabi-gcc -c -I../../ppc405_0_sw_platform/ppc405_0/include -g -O0 -omain.o ../main.c
Building target: ledt.elf
powerpc-eabi-gcc -o ledt.elf main.o     -L../../ppc405_0_sw_platform/ppc405_0/lib
Finished building: ledt.elf
************** Validating ELF File **************
Validating ELF Section Addresses with Hardware Address Map...
elfcheck -noheader -mhs C:/Xilinx/system1.mhs -p xc4vfx60ff1152-12 -xmpdir C:/Xilinx -pe ppc405_0 ledt.elf
ERROR:MDT - Section .rodata located at address 0xFFFF0430 does not map to any
   memory found in the hardware design.
ERROR:MDT - Section .sdata2 located at address 0xFFFF0434 does not map to any
ERROR:MDT - Section .sbss2 located at address 0xFFFF0434 does not map to any
ERROR:MDT - Section .data located at address 0xFFFF0434 does not map to any
ERROR:MDT - Section .got1 located at address 0xFFFF052C does not map to any
ERROR:MDT - Section .got2 located at address 0xFFFF052C does not map to any
ERROR:MDT - Section .ctors located at address 0xFFFF0548 does not map to any
ERROR:MDT - Section .dtors located at address 0xFFFF0550 does not map to any
ERROR:MDT - Section .fixup located at address 0xFFFF0558 does not map to any
ERROR:MDT - Section .got located at address 0xFFFF0558 does not map to any
ERROR:MDT - Section .eh_frame located at address 0xFFFF0558 does not map to any
ERROR:MDT - Section .jcr located at address 0xFFFF0560 does not map to any
ERROR:MDT - Section .gcc_except_table located at address 0xFFFF0564 does not map
   to any memory found in the hardware design.
ERROR:MDT - Section .sdata located at address 0xFFFF0564 does not map to any
ERROR:MDT - Section .sbss located at address 0xFFFF056C does not map to any
ERROR:MDT - Section .bss located at address 0xFFFF056C does not map to any
ERROR:MDT - Section .stack located at address 0xFFFF0588 does not map to any
ERROR:MDT - Section .heap located at address 0xFFFF1590 does not map to any
ERROR:MDT - elfcheck failed!
INFO:MDT - Try using the linker script generation tools to generate an ELF that
   maps well to your hardware design.
make: *** [ledt.elf] Error 2
Build complete for project ledt
Re: compilation error
Guess it is the problem with memory mapping ..
1) Check the linker script and map the sections to the memory available
2) Check the Addresses tab to see if the external memory controller is mapped to appropriate address ...
May be this helps
archu
Archu
May be this helps
archu
Archu
thamks
i solve the problem that is linker scripts problem
