Visitor poorya
ddr2_sdram_MPMC as Code Section
Hi all,
I have large C++ project in SDK that overflows, because of this i used ddr2_sdram and 4K cach, but in SDK the board cannot be programed.
I have a XC5VLX50T fpga and at first i used 64 KB bram that was not anough for my C codes.
how can i program my board with ddr2_sdram_MPMC as Code Section?
Poorya
Scholar sampatd
Re: ddr2_sdram_MPMC as Code Section
What is the error message you see in SDK?
What are your linker script settings in SDK?
Visitor poorya
Here is a part of error in SDK:
c:/xilinx/14.2/ise_ds/edk/gnu/microblaze/nt64/bin/../lib/gcc/microblaze-xilinx-elf/4.6.2/../../../../microblaze-xilinx-elf/bin/ld.exe: region `ilmb_cntlr_dlmb_cntlr' overflowed by 11048 bytes
collect2: ld returned 1 exit status
make: *** [SYSMON_cpp_0.elf] Error 1
And I have attached a image that shows my linker script settings in SDK.
I use ISE 14.2.
linker script
Visitor poorya
Excuse me, maybe my describtion was not good!
I want to place my C codes in ddr2_sdram instead of bram or ilmb_cntlr_dlmb_cntlr.
All you need to do is to use the drop-down in the generate linker script option for code to select ddr2.
Refer to the snapshot attached.
--Hem
Visitor poorya
Hi, Hem.
Thank you.
I did it. but programming the boared failes again as you see in the snapshot bellow.
what should i do?
The application is residing in the external memory. So when you program the FPGA using SDK, you should have bootloop.elf initialized. To program the FPGA, go to XIlinx TOols --> Program FPGA.
This is as shown here.
--Hem
Visitor poorya
Re: ddr2_sdram_MPMC as Code Place
Thanks Hem.
I did it, but it seems the design does not work!
What shoud i do?
Visitor poorya
someone help me please!
