rourabpaul
delta sigma adc
Im new in edk platform,(using spartan 3E)
I have notice that there is two types of IP in xilinx edk 11.1
1. I.P.s like dip,push button,ethernet,urlite,sdram,flash memory ect. we are adding these ips during the bulding of BSB.
2.  I.P.s like adc,dac,ps/2 etc. We can add these I.Ps after buliding the BSB.
What is the difference b/w them?
Im going to add the delta sigma adc with my project. as per i think the four ports of this ip these ports
IM2INTC, Agtr, DACout, and Sample should be external port. ami i right?
if it is right then i must edit the .ucf file also, in that could anyone tell me that pin numbers?.
before this project i was trying a vhdl code for adc(J7). I saw in that case the ports are CLK,SPI_miso,SPI_mosi,AMP_shdn.SPI_clk ect
why these port are missing when i using a proccessor.is these ports are controlled by processor itself??
rourabpaul
Now i successfully added the delta sigma adc, it has 4 port M2INTC, Agtr, DACout, and Sample, what should i do with port?
should i make it external port??
is there anybody to rply
rourabpaul
as per i know only Agtr is an input signal and others are output, could i make all these port open, or could i connect Agtr to a dip switch and outputs in LEDs?
rourabpaul
there is no any experts in xilinx forum can give some suggestions about delta sigma adc ?:smileysad:
is it?? or everybody overlooked my thread??
im eagarly waiting ...............................
rourabpaul
i dnt understand what will be the connection of agtr?
