Observer jorsong
edk can't use ise ipcore
I'm using ise edk 9.1i,.
I generated a custom Ip core in edk, and edit it in ise with ..I use ise generate a fifo with fifo generator,instantiate in my ise project,I can  synthesize it correctly in ise...but when I use edk to synthesize ,it tells me the fifo that I generated in ise can not be resolved.......
how to use ise ip core correctly in edk....help me please....
Thanks a lot!!!
Re: edk can't use ise ipcore
You may find this thread helpful:
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=5634 (Put Coregen component into EDK library?)
Cheers,
bt
Cheers,
bt
