451582319
edk elfcheck failed
hi ,i used edk13.4,when i use debug as->launch on hardware ,an error appeared
ERROR:EDK:3165  -  elfcheck  failed!
The  following sections did not fit into Processor BRAM memory:
               Section .jcr  (0x9000014cC-0x9000014F)
               Section .eh_frame  (0x90000148-0x9000014B)
               Section .data  (0x90000018-0x90000147)
               Section .rodata  (0x90000010-0x90000015)
               Section .dtors   (0x90000008-0x9000000F)
               Section .eh_frame  (0x90000000-0x90000007)
Try using the linker script generation tools to generate an ELF that maps
correctly to your hardware design.
My mpmc_baseaddress is 0x90000000.length is 0x10000000
In the table "generate a linker script" whent i change the Basic->Place Data Sections in: and Place Heap and Stack in :
from "ilmb_cntlr_dlmb_cntlr" to my mpmc_baseaddr ,this error occured.
htsvn
Are you trying to use SDK --> Xilinx Tools --> Program FPGA --> With an ELF other than bootloop.elf?
--HS
451582319
i used sdk-> xilinx Tools->Program FPGA->With an ELF ,because when i used  the bootloop.elf ,an error occured
error:Data2MEM:1 - File '\xilinx\13.4\ISE_DS\EDK\sw\lib\microblaze\mb_bootloop.elf' can not be found.or is busy
Please ensure that the file is available inthe correct directory location,or isn't being locked by another application.
and i checked the directory location ,and i found the bootloop file ,and i just use the only one sdk .
hvlsn
I have the same problem. When I program Fpga with bootloop.elf file. It works. But when I use release.elf file this error occur. I can not download lwip_echo_server release elf file. What is the reason of this problem? I changed linker script like place code section DDR2, place data section DDR2, and place heap &Stack in DDR2. What is wrong?
