Observer zfima
error: lwip/sockets.h: No such file or directory
In xps i make bsp with ethernet interrupt, move it to SDK. In SDK add LwIP, so i get a lot of LwIP headers. But next simple code make error:
#include "lwip/sockets.h"
int main()
	int i = AF_INET;
	return 0;
error:
**** Build of configuration Debug for project empty_cpp_0 ****
make all
Building file: ../src/main.cc
Invoking: MicroBlaze g++ compiler
mb-g++ -Wall -O0 -g3 -c -fmessage-length=0 -mxl-soft-mul -MMD -MP -MF"src/main.d" -MT"src/main.d" -o"src/main.o" "../src/main.cc"
../src/main.cc:4:26: error: lwip/sockets.h: No such file or directory
../src/main.cc: In function ‘int main()’:
../src/main.cc:8: error: ‘AF_INET’ was not declared in this scope
../src/main.cc:8: warning: unused variable ‘i’
make: *** [src/main.o] Error 1
 Where is catch???
When i point on "lwip/sockets.h" and press F3 button, i can see the header file. I miss some paths?
Re: error: lwip/sockets.h: No such file or directory
1. In software platform settings, make sure that you have included 'lwip' library.
2. If it has been included, then make sure that, in OS and library settings, in under 'lwip' library, you have set SOCKET API, as by default it is RAW API
Observer zfima
Thank you!!!
2 works
Observer zfima
My troubles continues....
Next code pass building, but fail on linking:
#include "lwip/init.h"
#include <stdio.h>
#include <string.h>
#include "lwip/inet.h"
#include "lwip/sys.h"
#include "lwipopts.h"
u16_t ECHO_PORT = 7;
int main()
	int sock, new_sd;
	struct sockaddr_in address, remote;
	int size;
	if ((sock = lwip_socket(AF_INET, SOCK_STREAM, 0)) < 0){
		return 0;
	address.sin_family = AF_INET;
	address.sin_port = htons(ECHO_PORT);
	address.sin_addr.s_addr = INADDR_ANY;
	if (lwip_bind(sock, (struct sockaddr *)&address, sizeof (address)) < 0){
		return 0;
	lwip_listen(sock, 5);
	return 0;
Error:
make all
mb-g++ -Wall -O0 -g3 -c -fmessage-length=0 -D __XMK__ -I../../xilkernel_bsp_LwIP/microblaze_0/include -mxl-pattern-compare -mcpu=v7.30.a -mno-xl-soft-mul -MMD -MP -MF"src/main.d" -MT"src/main.d" -o"src/main.o" "../src/main.cc"
../src/main.cc:12: warning: unused variable ‘new_sd’
../src/main.cc:13: warning: unused variable ‘remote’
../src/main.cc:14: warning: unused variable ‘size’
Finished building: ../src/main.cc
Building target: empty_cpp_0.elf
Invoking: MicroBlaze g++ linker
mb-g++ -L../../xilkernel_bsp_LwIP/microblaze_0/lib -mxl-pattern-compare -mcpu=v7.30.a -mno-xl-soft-mul -o"empty_cpp_0.elf"  ./src/main.o   -lxilkernel -llwip4
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_mbox_post':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:247: undefined reference to `sem_wait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:266: undefined reference to `sem_post'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:269: undefined reference to `sem_post'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_sem_signal':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:164: undefined reference to `sem_post'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_arch_mbox_fetch':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:306: undefined reference to `sem_wait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:314: undefined reference to `xget_clock_ticks'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:327: undefined reference to `sem_wait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:314: undefined reference to `sem_post'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:319: undefined reference to `xget_clock_ticks'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:324: undefined reference to `sem_timedwait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:342: undefined reference to `sem_post'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:353: undefined reference to `sem_wait'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_arch_sem_wait':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:140: undefined reference to `xget_clock_ticks'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:143: undefined reference to `sem_timedwait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:160: undefined reference to `xget_clock_ticks'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:150: undefined reference to `sem_wait'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_mbox_trypost':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:276: undefined reference to `sem_trywait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:294: undefined reference to `sem_post'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:297: undefined reference to `sem_post'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_mbox_free':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:236: undefined reference to `sem_wait'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:238: undefined reference to `sem_destroy'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:239: undefined reference to `sem_destroy'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_sem_free':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:173: undefined reference to `sem_destroy'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_mbox_new':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:204: undefined reference to `sem_init'
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:213: undefined reference to `sem_init'
../../xilkernel_bsp_LwIP/microblaze_0/lib/liblwip4.a(sys_arch.o): In function `sys_sem_new':
/cygdrive/d/Temp/Vertex/XPS/Temp12_LwIP/SDK/SDK_Workspace_35/xilkernel_bsp_LwIP/microblaze_0/libsrc/lwip130_v2_00_a/src/contrib/ports/xilinx/sys_arch.c:118: undefined reference to `sem_init'
collect2: ld returned 1 exit status
make: *** [empty_cpp_0.elf] Error 1
i try add something to linker in options, like dir path or library but it not help....
please, help me
Check under OS and Lib configuration that you have taken config_sema = TRUE, and in systtmr_dev = xps_timer (in systmr_spec).
also check that config_time = TRUE
Observer zfima
Thanks a lot!!!! U R great!!!
