failed to copy to cache - EDK 12.4
Dear Members;
 I am getting the following error when I am trying to generate netlist in EDK. I am using Xilinx 12.4 and targeting a SP605 Dev. board. Here is the error:
Done!
Writing NGCBUILD log file "../clock_generator_0_wrapper.blc"...
NGCBUILD done.
Rebuilding cache ...
ERROR:EDK:1588 - IPNAME:mb_plb_wrapper INSTANCE:mb_plb -
   P:\VSoC_Projects\SP605\Latest_Functional_Design\cpu\cpu.mhs line 127 - failed
   to copy to cache
ERROR:EDK:1588 - IPNAME:sdram_0_wrapper INSTANCE:sdram_0 -
   P:\VSoC_Projects\SP605\Latest_Functional_Design\cpu\cpu.mhs line 187 - failed
   to copy to cache
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/microblaze_0_wrapper.ngc] Error 2
Any help is appreciated...
Re: failed to copy to cache - EDK 12.4
Hi Dylan;
 The problem is solved. We needed to perform an install on a clean VM.
Hmm, what if you move your project to the local C:\ drive? What is the P:\ drive exactly?
Hi Dylan;
Visitor gggaaromn
Hello, Airturk
When you mention the 'VM', what does it mean?
