fatal error: xintc.h: No such file or directory
Accepted Solution Solved
Accepted Solution
I have received the error :
fatal error: xintc.h: No such file or directory xiic_slave_example.c /standalone_bsp_0_xiic_slave_example_1/src line 78 C/C++
Any solutions possible please?
Thank you,
Re: fatal error: xintc.h: No such file or directory
@doner_t  Likely you do not have an interrupt controller in your design. That is the most common cause.
But it might be that the BSP was not generated correctly. In this case regenerate it (or create a new one and re-reference it) then clean and build your project again.
All Replies
