dasco1632
g++/gcc not found in PATH
HI all,
I am trying to (clean) build a project in Xilinx SDK, but i am getting this error.
i am using a vivado webpack 2017.4, installed on D drive (instead of default C drive)
Does anybody have any idea how to solve this issue?
Thanks in advance!
arpansur
Hi @dasco1632,
Can you please try adding the GNU path to the PATH variable and see if the issue persists?
Arpan
dasco1632
Hello Arpan,
Can you elaborate?
arpansur
Hi @dasco1632
echo %PATH% in cmd
In case you don't see the path to GNU then try adding the same till the bin
Arpan
dasco1632
@arpansur
I looked into the sdk/bin and i don't see g++ or gcc  exe's
 but in ~\SDK\2017.4\gnu\microblaze\nt\bin
i see mb-gcc.exe and mb-g++.exe
