Participant linuxbest
how can I access the microblaze LMB BRAM from PPC.
hi.
I design a system base on V5FXT100T, I using PPC440 as system CPU running Linux, and have a microblaze running some code, Now I need update the mb instruction memory from the linux.
can someone give me helps.
thanks.
Re: how can I access the microblaze LMB BRAM from PPC.
Your BRAM has 2 ports: PORTA and PORTB.
PORTA could be connected to one LMB_BRAM_CONTROLLER and PORT_B could be connected to one XPS_BRAM_controller.
PowerPC writes to the XPS_BRAM_CONTROLLER through the PLB.
Microblaze reads from the LMB_BRAM_CONTROLLER through the LMB_BRAM
Bye
DABG
Bye
DABG
yes,  using dual port ram is a method.
If xilinx can open the mdm protocol, we can access the mb in linux using the mdm interface, I more prefect this method.
