Participant aaron_eda
how to get previous version ipcores?
hello, everyone.
today, i want open a xps project with my edk v10.1, but there are some errors about ipcores as follows:
RROR:MDT - IPNAME:opb_ps2_dual_ref HW_VER:1.00.a - Can not find valid MPD
ERROR:MDT - IPNAME:opb_ps2_dual_ref HW_VER:1.00.a - Can not find valid MPD
ERROR:MDT - IPNAME:dual_ps2_ioadapter HW_VER:1.00.a - Can not find valid MPD
ERROR:MDT - IPNAME:opb_ps2_dual_ref INSTANCE: PS2_Ports - F:\code\code\myxps\system.mhs line 159 - could not find the MPD!
ERROR:MDT - IPNAME:dual_ps2_ioadapter INSTANCE: PS2_Ports_IO_ADAPTER - F:\code\code\myxps\system.mhs line 191 - could not find the MPD!
are these two ip cores along with edk installation?
can i  get these ip cores free?
best regards
aaron
Re: how to get previous version ipcores?
Hi Aaron,
Those cores are not EDK released cores. They should come with the project that you are using.
-XF
Hello.
If you want to know whether cores are given by xilinx or not then check your PCORES folder in your project folder.
If any custom core is used in the project then it is stored in the Pcores folder.
Normally the folder stays empty if all the cores used in the project are given by xilinx.
Best of luck.
Unlimited in my Limits.
Hello, thank you.
I found data sheet of these ip cores Xilinx's web pages.
Can I apply for using these ip cores at evaluation version ?
Best regards,
AARON
Hello.
Yes you can use these cores the way you want in the evaluation mode.
Best of luck.
