how to remove my custom ip cores in EDK ip catalog?
hi,everyone!
   I created a custom ip cores in EDK,now I want to remove it from the catalog,but I can't find the method to do this.If I remove the dir named pcores in the project dir,and the <project Dir>\drivers\<pcores drivers>, the core's name I created disappears,but When I use the CIP next time,The core's name is still in there,and I can't create a new IP cores?
    Someone else have the same problem?
    Thanks!
Tags (5)
because  I entered the name ofcore in upper case, so I couldn't go to the next step,Now I can create a new IP core with CIP.
It  confuse me that why I can enter the name of the core in upper case,but now I can't?
You mean, you want to remove custom IP from  EDK USER pcores?
You should remove it from the pcores catalog in your project directory.
Only lower case letters are allow, I suppose.
