iic example for microblaze
Can anyone point me to an example (.c) for iic IP running with Microblaze in EDK?
DeWayne
Voyager
Voyager
Re: iic example for microblaze
DeWayne,
Xilinx provides some good code examples in your EDK installation.  Look under %XILINX_EDK%\sw\XilinxProcessorIPLib\drivers\iic_v1_13_b\examples.  I am working on an example based on xiic_repeated_start_example.c that accesses the TI TMP100 temp sensor from MicroBlaze (EDK 10.1.03).  I hope to have it posted next week here www.em.avnet.com/spartan3a-evl.
Bryan
There is a reference design for OPB based IIC.
Refer <http://www.xilinx.com/support/documentation/application_notes/xapp979.pdf>
Voyager
Voyager
DeWayne,
Bryan
Bryan,
Thanks for pointing out the existence of the examples folder for the I2c drivers.  This will help out alot!
Cheers.
Phil
iic read problem!
hi,
am using spartan 6 fpga to interface decoder through i2c,
for this am using xps_iic microblaze core, here when i send data onto sda line there am able to see only device id and ack sent by slave this is continously(address ack their is low to high pulse again address ack low to high pulse.....) repeating but actual data is not their on the sda line, plz give a solution to my problem?
