stfarley
import pdf file in SDK (2018.3)
In SDK 2018.3 attempting to import a hardware specification via <file/new/other/Hardware Platform Specification>
Doesn't seem to work as the hardware selection window only allows .xml files. Vivado only generates an hdf file.
Is there a change to this flow for 2018.3
stfarley
Sorry about that subject line. I didn't note the spell correction until it was too late
glena
file formats of xml, hdf, and dsa are accepted in SDK 2018.3
stfarley
Hmm, Something strange is going on then.
The file extention selector button will not change from *.xml
glena
Which OS are you running?   I'm on Win7
stfarley
Centos 7.
stfarley
If I export the harware from Vivado, Then select lauch sdk and point to the export directory everything seems to work.
It appears then that this is a GUI bug in SDK under linux.
