Participant sshilpa
microblaze, sleep()
Am using EDK 11.1 and microblaze is the processor.
I need to use sleep() in my software program.
What is the syntax and the corresponding header file for the sleep function?
Re: microblaze, sleep()
MicroBlaze doesn't have a timer. So no sleep() function without a timer.
You can add a timer into the system and implement your sleep() function.
-XF
-XF
The sleep function is available if you use XMK and of course has to be configured to include a timer.
unsigned sleep(unsigned int ms)
Parameters
ms is the number of milliseconds to sleep.
Returns Number of seconds between sleeps.
0 on complete success.
Description This routine causes the invoking process to enter a sleep state for the
specified number of milliseconds.
Includes
xmk.h, sys/timer.h
BR
Participant sshilpa
Thanks for the reply.
regards,
Shilpa
Is it possible to use sleep function without using XMK?
I am using microbalze, ISE 11.3, and virtex-5.
Not really since sleep function it's part of the XMK and it requires a timer.
You can however create your own sleep function by using FSL and a hardware counter
Just create a loadable 32-bit counter, connect a master fsl data as the loadable value and a master fsl write signal as the load signal.
Make sure that the counter has a signal which is '1' when it reach 0 and that it stops counting when it reach zero.
Connect this signal to a master slave exist input on MicroBlaze.
If you now want to sleep (stalling), just execute a put instruction with the sleep value and then do a blocking get.
This will make MicroBlaze stall until the counter has reach zero.
If you enable the extended FSL support, MicroBlaze can still handle interrupts while sleeping.
Göran
Göran,
Your solution was so elegant. Thanks! I implemented a sleep function using blocking FSL.
Now, I need to support interrupts while sleeping. Can you point me to some references regarding "extended FSL support".
aminfar
Just set C_USE_EXTENDED_FSL_INSTR = 1 on MicroBlaze.
This will make the blocking fsl instructions interruptable.
MicroBlaze will jump to the interrupt handler while it's stalling on a blocking FSL instruction and jump back to the blocking FSL instruction when the interrupt handler returns with "RTID" instruction.
Don't forget to enable interrupts.
Göran
