Visitor mackalli
no "device-tree selection" in Board Support Package OS
Hi  xilinx hacker, I have try using ISE4.7, Vivado2013.3, Vivado2013.4, Vivado2014.1 under Ubuntu12.04LTS, CentOS6.4 final version for generating device tree, but it failed failed again.  it just like the picture: there is no selection of device-tree.
just standalone for selecting.  anyone can tell me what the reason is??
Visitor mackalli
Re: no "device-tree selection" in Board Support Package OS
Yes, I have try this, I have spent 3 days for it. but now I have generated the device-tree on win7 platform using vivado2013.4...  I modify the installed file.....  Thank you for your reply......
After adding the BSP repository in SDK, did you select Rescan Repository and then select Apply and then try to re-create the BSP?
Debraj
Visitor mackalli
Great! If you don't mind can you post your system.mss file from the generated device-tree_bsp?
Debraj
