only link the source file in main funtion in Xilinx SDK debugger.
Here is a weird problem I'm having right now.
when I follow this website to debug the application on SDK.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/SDK_Doc/SDK_tasks/sdk_t_tcf_standalone_app_debug_tcf.html
it just only link the main.c in the debugger.
I can see the main.c is correctly linking with the Disassembly, which is really good.
but when I step into any of the functions in the main.c, it will just show the Disassembly page.
for example:
I can see that main.c is linked with Disassembly here
Screenshot from 2016-06-10 12:18:17.png
But when I step into any of these function. it only shows the Disassembly.
Screenshot from 2016-06-10 12:22:01.png
so far the only way I know is adding a symbol files on right clicking the processor. but It already has an elf file inside.
So I don't know what's going on here.
Is there any setting I can use to make this correct?
