petalinux-v2017.3-final-installer.run missing xvfb-run
I have been trying to upgrade my petalinux by installing the "petalinux-v2017.3-final-installer.run" on my Ubuntu 16.04 machine. I also downloaded the 2017.3 Zedboard BSP.
When I go through the "petalinux-v2017.3-final-installer.run" installation, I had bunch of missing packages which I was able to get by "apt-get update" and "apt-get install -y <missing_package_names>. I was able to get most of them except "xvfb-run" and "textinfo". Has anyone ran into the same issue as you upgraded your Petalinux to 2017.3 and how did you resolve it?
Aynilian.
Hi all,
I think I solved it:
sudo apt-get install xvfb  did the trick.
successfully installed petalinux-v2017.3-final-installer.run.
Aynilian
Post once.
We will see it.
Austin Lesea
Principal Engineer
Xilinx San Jose
Austin,
Why can't I see my post in the "Embedeed Linux" Forum? If I post it once, is there a way to show my post in multiple forums?
Aynilian
Because one post suffices.
If not answered, it gets flagged by a moderator to pursue.
If you multiple post, you clutter up the boards, and we will clean it up.
Again, one post is completely sufficient.
Even in the wrong board (it will just get moved to the 'right' board).
In this vibrant closely watched community (forums.xilinx.com), you will get an answer.  And you will get it faster.
My answer to your question is "did you setup the github referenced properly?"
This allows the Petalinux build process to go find everything needed.
At least, that was (one) problem I had.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin,
I'm not sure how to do this "github referenced properly?"
Does this constitute modifying "/etc/apt/source.list" and changing the attributes to "universe or multiverse" in-front of
"deb http://archive.ubuntu.com/ubuntu" ?
Aynilian
No,
That is not it.  Now I cannot find it.  But I do recall that building petalinux I needed to have a means of allowing sources to get pulled from the github.  Fuzzy now, I cannot remember the details ,,,
Austin Lesea
Principal Engineer
Xilinx San Jose
I edited /etc/apt/sources.list.
I did this:
cd /etc/apt/
$/etc/apt/ sudo chmod 666 sources.list  "This was necessary, because the file was in read only mode"
/etc/apt/gedit sources.list
changed this section by adding universe multiverse:
 deb http://us.archive.ubuntu.com/ubuntu/ xenial-updates main restricted universe multiverse
 deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-updates main restricted universe multiverse
then I did this
apt-get install -y xvfb-run  (E: Unable to locate package xvfb-run)
apt-get install -y texinfo (Got it!_
Then went back and re-ran the installations:
./petalinux-v2017.3-final-installer.run
Partial success!
Now I'm down to 1 missing package (xvfb-run).
Thx
Aynilian
apt-get did not find it by searching, I found and downloaded xvfb-run.1.gz from an ubuntu website.
How do I install xvfb-run.1.gz that is in my Downloads directory?
Aynilian
Hi all,
Aynilian
