rajuponnaganti
Voyager
Voyager
problem with custom ip
i cteated and packaged ip called myip_asser2 in s-axi_in slave mode.
i added following code c <= a +b;(31 downto 0) for signals a,c and b.
a is assigned to slv_reg_0,b is to slv_reg_1 and c -s to slv-reg_2.
in sdk , my code is
u32 data_1;
Xil_Out32(XPAR_MYIP_ADDER_V2_0_S00_AXI_BASEADDR, 0x00001234);
Xil_Out32(XPAR_MYIP_ADDER_V2_0_S00_AXI_BASEADDR+4, 0xabcd1234);
data_1 = Xil_In32(XPAR_MYIP_ADDER_V2_0_S00_AXI_BASEADDR+8);
xil_printf("added value: %x\n\r",data_1);
 i didnt get output;
i am getting output is 0;
need solution.
i dont know why it is giving out put.
pvenugo
Try using
Xil_Out32(XPAR_MYIP_ADDER_V2_0_S00_AXI_BASEADDR+4, 0x00001234);
Xil_Out32(XPAR_MYIP_ADDER_V2_0_S00_AXI_BASEADDR+8, 0xabcd1234)
Praveen
pvenugo
Also, if possible pls share ur desing and SDK workspace.
Praveen
rajuponnaganti
Voyager
Voyager
 i am attaching sdk file as zip.try to solve.
we are using vc707 board.
waiting for solution.
rajuponnaganti
Voyager
Voyager
have you check this?
rajuponnaganti
Voyager
Voyager
what is the solution?
signature20
Did you get any solution for this issue ?
I am facing a similar problem with Vivado 2017.4
Shreya
rajuponnaganti
Voyager
Voyager
Yes
signature20
what is it?
