cyn_thia
put variable or functions on the OCM in bare metal application.
HI:
    How can I put the variables  and the functions  on the OCM in the bare-metal application ? I am using VIVADO 2016.4.
    Thanks very much!
ibaie
Hi @cyn_thia
There are different ways to do this, specially for the variables but I think that the best way is through the linker script and the usage of sections.
The first thing is to define a section in the OCM in your linker script where you want to place your function and variables, you can do either by Linker script generator or by modifying the linker script in text file.
i.e. two sections defined in OCM to place data and text
.OCM.data : {
__OCM_start = .;
*(.OCM)
__OCM_end = .;
} > ps7_ram_0
.OCM.text : {
__OCM_start = .;
*(.OCM)
__OCM_end = .;
} > ps7_ram_0
C code placing variables and functions in those sections:
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
int ret __attribute__((section(".OCM.data"))) = 0;
int main(void) __attribute__((section(".OCM.text")));
int main()
    init_platform();
    print("Hello World\n\r");
    cleanup_platform();
    return ret;
Ibai
ibaie
Hi @cyn_thia
.OCM.data : {
__OCM_start = .;
*(.OCM)
__OCM_end = .;
} > ps7_ram_0
.OCM.text : {
__OCM_start = .;
*(.OCM)
__OCM_end = .;
} > ps7_ram_0
#include <stdio.h>
int main()
    init_platform();
    cleanup_platform();
    return ret;
Ibai
cyn_thia
 It's the perfect solution to my problem.Thanks !
