chen71730
question on microblaze disassembler
Hi!
Option "-S" of microblaze disassembler is used for intrmix source code with disassembly.
Why  are the below messages appeared when I use this option?
the command is:
powerpc-eabi-objdump -Ss TestApp_Peripheral.elf >> TestApp_Peripheral.dis
the message is:
powerpc-eabi-objdump: Can't disassemble for architecture UNKNOW!
.elf file had already been generated successfully. What's the matter about this message?
can anyone tell me? thank you so much.
vsiva
You might want to post the header that you see when you do:
powerpc-eabi-readelf -a executable.elf
Specifically, make sure that it says that the machine is PowerPC.
jagron
The power-pc-eabi tools are for PowerPC 405/440 ELF files.  To work with MicroBlaze files, one must use the mb-tools, i.e.
mb-objdump
mb-gcc
etc.
-Jason
chen71730
Thank you both. Sorry! I seem to make a logical mistake.
I can get disassembly code after using the following command
mb-objdum -S TestApp_Peripheral.elf >> TestApp_Peripheral.dis
Thank you for your help. :)
