questions about LMB BRAM interface Controller
I have some problems when I am learning the LMB BRAM interface Controller(v2.00a)
I can not understand the code of it.
library ieee;
use ieee.std_logic_1164.all;
library proc_common_v1_00_c;
use proc_common_v1_00_c.pselect_mask;
entity lmb_bram_if_cntlr is
  generic (
    C_HIGHADDR   : std_logic_vector(0 to 31) := X"00000000";
    C_BASEADDR   : std_logic_vector(0 to 31) := X"FFFFFFFF";
    C_MASK       : std_logic_vector(0 to 31) := X"00800000";
    C_LMB_AWIDTH : integer                   := 32;
    C_LMB_DWIDTH : integer                   := 32
  port (
    LMB_Clk : in std_logic := '0';
    LMB_Rst : in std_logic := '0';
    -- Instruction Bus
    LMB_ABus        : in  std_logic_vector(0 to C_LMB_AWIDTH-1);
    LMB_WriteDBus   : in  std_logic_vector(0 to C_LMB_DWIDTH-1);
    LMB_AddrStrobe  : in  std_logic;
    LMB_ReadStrobe  : in  std_logic;
    LMB_WriteStrobe : in  std_logic;
    LMB_BE          : in  std_logic_vector(0 to (C_LMB_DWIDTH/8 - 1));
    Sl_DBus         : out std_logic_vector(0 to C_LMB_DWIDTH-1);
    Sl_Ready        : out std_logic;
    -- ports to memory block
    BRAM_Rst_A  : out std_logic;
    BRAM_Clk_A  : out std_logic;
    BRAM_Addr_A : out std_logic_vector(0 to C_LMB_AWIDTH-1);
    BRAM_EN_A   : out std_logic;
    BRAM_WEN_A  : out std_logic_vector(0 to C_LMB_DWIDTH/8-1);
    BRAM_Dout_A : out std_logic_vector(0 to C_LMB_DWIDTH-1);
    BRAM_Din_A  : in  std_logic_vector(0 to C_LMB_DWIDTH-1)
end lmb_bram_if_cntlr;
architecture imp of lmb_bram_if_cntlr is
-- component declarations
  component pselect_mask is
    generic (
      C_AW   : integer                   := 32;
      C_BAR  : std_logic_vector(0 to 31) := X"00000000";
      C_MASK : std_logic_vector(0 to 31) := X"00800000");
    port (
      A     : in  std_logic_vector(0 to 31);
      CS    : out std_logic;
      Valid : in  std_logic);
  end component;
-- internal signals
  signal lmb_select : std_logic;
  signal lmb_select_1 : std_logic;
  signal lmb_we : std_logic_vector(0 to 3);
  signal Sl_Ready_i : std_logic;
begin  -- architecture IMP
  -- Top-level port assignments
  -- Port A
  BRAM_Rst_A  <= '0';
  BRAM_Clk_A  <= LMB_Clk;
  BRAM_EN_A   <= '1';
  BRAM_WEN_A  <= lmb_we;
  BRAM_Dout_A <= LMB_WriteDBus;
  Sl_DBus     <= BRAM_Din_A;
  BRAM_Addr_A <= LMB_ABus;
--the code below, I can not understand
  -- Handling the LMB bus interface
  -- Writes are pipelined in MB with 5 stage pipeline
  Ready_Handling : process (LMB_Clk, LMB_Rst) is
  begin  -- PROCESS Ready_Handling
    if (LMB_Rst = '1') then
      Sl_Ready    <= '0';
    elsif (LMB_Clk'event and LMB_Clk = '1') then  -- rising clock edge
      Sl_Ready    <= lmb_select;
    end if;
  end process Ready_Handling;
  lmb_we(0) <= LMB_BE(0) and LMB_WriteStrobe and lmb_select;
  lmb_we(1) <= LMB_BE(1) and LMB_WriteStrobe and lmb_select;
  lmb_we(2) <= LMB_BE(2) and LMB_WriteStrobe and lmb_select;
  lmb_we(3) <= LMB_BE(3) and LMB_WriteStrobe and lmb_select;
  -- Do the LMB address decoding
  pselect_mask_lmb : pselect_mask
    generic map (
      C_AW   => LMB_ABus'length,
      C_BAR  => C_BASEADDR,
      C_MASK => C_MASK)
    port map (
      A     => LMB_ABus,
      CS    => lmb_select,
      Valid => LMB_AddrStrobe);
end architecture imp;
entity pselect_mask is
  generic (
    C_BAR  : std_logic_vector(0 to 31) := "00000000000000100000000000000000";
    C_MASK : std_logic_vector(0 to 31) := "00000000000001111100000000000000"
  port (
    A     : in  std_logic_vector(0 to C_AW-1);
    Valid : in  std_logic;
    CS    : out std_logic
end entity pselect_mask;
-- Architecture section
library unisim;
use unisim.all;
architecture imp of pselect_mask is
--  component LUT4
--    generic(
--      INIT : bit_vector := X"0000"
--    port (
--      O  : out std_logic;
--      I0 : in  std_logic := '0';
--      I1 : in  std_logic := '0';
--      I2 : in  std_logic := '0';
--      I3 : in  std_logic := '0');
--  end component;
--  component MUXCY is
--    port (
--      CI : in  std_logic;
--      DI : in  std_logic;
--      S  : in  std_logic
--  end component MUXCY;
  function Nr_Of_Ones (S : std_logic_vector) return natural is
    variable tmp : natural := 0;
  begin  -- function Nr_Of_Ones
    for I in S'range loop
      if (S(I) = '1') then
        tmp := tmp + 1;
      end if;
    end loop;  -- I
    return tmp;
  end function Nr_Of_Ones;
  function fix_AB (B : boolean; I : integer) return integer is
  begin  -- function fix_AB
    if (not B) then
      return I + 1;
    else
      return I;
    end if;
  end function fix_AB;
  constant Nr      : integer := Nr_Of_Ones(C_MASK);
  constant Use_CIN : boolean := ((Nr mod 4) = 0);
  constant AB      : integer := fix_AB(Use_CIN, Nr);
  attribute INIT : string;
  constant NUM_LUTS    : integer := (AB-1)/4+1;
--   signal   lut_out     : std_logic_vector(0 to NUM_LUTS-1);
--   signal   carry_chain : std_logic_vector(0 to NUM_LUTS);
  -- function to initialize LUT within pselect
  type int4 is array (3 downto 0) of integer;
  function pselect_init_lut(i        : integer;
                            AB       : integer;
                            NUM_LUTS : integer;
                            C_AW     : integer;
                            C_BAR    : std_logic_vector(0 to 31))
    return bit_vector is
    variable init_vector : bit_vector(15 downto 0) := X"0001";
    variable j           : integer                 := 0;
    variable val_in      : int4;
  begin
    for j in 0 to 3 loop
      if i < NUM_LUTS-1 or j <= ((AB-1) mod 4) then
        val_in(j) := conv_integer(C_BAR(i*4+j));
      else val_in(j) := 0;
      end if;
    end loop;
    init_vector := To_bitvector(conv_std_logic_vector(2**(val_in(3)*8+
                                                          val_in(2)*4+val_in(1)*2+val_in(0)*1),16));
    return init_vector;
  end pselect_init_lut;
  signal A_Bus : std_logic_vector(0 to AB);
  signal BAR   : std_logic_vector(0 to AB);
-- Begin architecture section
begin  -- VHDL_RTL
  Make_Busses : process (A,Valid) is
    variable tmp : natural;
  begin  -- process Make_Busses
    tmp   := 0;
    A_Bus <= (others => '0');
    BAR   <= (others => '0');
    for I in C_MASK'range loop
      if (C_MASK(I) = '1') then
        A_Bus(tmp) <= A(I);
        BAR(tmp)   <= C_BAR(I);
        tmp        := tmp + 1;
      end if;
    end loop;  -- I
    if (not Use_CIN) then
      BAR(tmp) <= '1';
      A_Bus(tmp) <= Valid;
    end if;
  end process Make_Busses;
--  More_Than_3_Bits : if (AB > 3) generate
--    Using_CIn: if (Use_CIN) generate
--      carry_chain(0) <= Valid;
--    end generate Using_CIn;
--    No_CIn: if (not Use_CIN) generate
--      carry_chain(0) <= '1';
--    end generate No_CIn;
--    GEN_DECODE : for i in 0 to NUM_LUTS-1 generate
--      signal lut_in : std_logic_vector(3 downto 0);
--    begin
--      GEN_LUT_INPUTS : for j in 0 to 3 generate
--        -- Generate to assign address bits to LUT4 inputs
--        GEN_INPUT : if i < NUM_LUTS-1 or j <= ((AB-1) mod 4) generate
--          lut_in(j) <= A_Bus(i*4+j);
--        end generate;
--        -- Generate to assign zeros to remaining LUT4 inputs
--        GEN_ZEROS : if not(i < NUM_LUTS-1 or j <= ((AB-1) mod 4)) generate
--          lut_in(j) <= '0';
--        end generate;
--      end generate;
---- RTL version without LUT instantiation for XST
--      lut_out(i) <= (lut_in(0) xnor BAR(i*4+0)) and
--                     (lut_in(1) xnor BAR(i*4+1)) and
--                     (lut_in(2) xnor BAR(i*4+2)) and
--                     (lut_in(3) xnor BAR(i*4+3));
---- Structural version with LUT instantiation for Synplicity (when RLOC is
----  desired for placing LUT
----    LUT4_I : LUT4
----      generic map(
----        -- Function init_lut is used to generate INIT value for LUT4
----        INIT => pselect_init_lut(i,C_AB,NUM_LUTS,C_AW,C_BAR)
----      port map (
----        O  => lut_out(i),  -- [out]
----        I0 => lut_in(0),   -- [in]
----        I1 => lut_in(1),   -- [in]
----        I2 => lut_in(2),   -- [in]
----        I3 => lut_in(3));  -- [in]
--      MUXCY_I : MUXCY
--        port map (
--          O  => carry_chain(i+1),       --[out]
--          CI => carry_chain(i),         --[in]
--          DI => '0',                    --[in]
--          S  => lut_out(i)              --[in]
--    end generate;
--    CS <= carry_chain(NUM_LUTS);        -- assign end of carry chain to output
--  end generate More_Than_3_Bits;
--  Less_than_4_bits: if (AB < 4) generate
    CS <= Valid when A_Bus=BAR else '0';
--  end generate Less_than_4_bits;
end imp;
  generic (
  port (
    CS    : out std_logic
library unisim;
use unisim.all;
--  component LUT4
--    generic(
--    port (
--  end component;
--    port (
--      S  : in  std_logic
        tmp := tmp + 1;
      end if;
    end loop;  -- I
    return tmp;
    if (not B) then
      return I + 1;
    else
      return I;
    end if;
                            AB       : integer;
                            NUM_LUTS : integer;
                            C_AW     : integer;
  begin
      end if;
    end loop;
    return init_vector;
begin  -- VHDL_RTL
    tmp   := 0;
        A_Bus(tmp) <= A(I);
        tmp        := tmp + 1;
      end if;
    end loop;  -- I
      BAR(tmp) <= '1';
    end if;
--    begin
--        end generate;
--        end generate;
--      end generate;
----    LUT4_I : LUT4
----      generic map(
----      port map (
--      MUXCY_I : MUXCY
--        port map (
--    end generate;
end imp;
  generic (
  port (
    CS    : out std_logic
library unisim;
use unisim.all;
--  component LUT4
--    generic(
--    port (
--  end component;
--    port (
--      S  : in  std_logic
        tmp := tmp + 1;
      end if;
    end loop;  -- I
    return tmp;
    if (not B) then
      return I + 1;
    else
      return I;
    end if;
                            AB       : integer;
                            NUM_LUTS : integer;
                            C_AW     : integer;
  begin
      end if;
    end loop;
    return init_vector;
begin  -- VHDL_RTL
    tmp   := 0;
        A_Bus(tmp) <= A(I);
        tmp        := tmp + 1;
      end if;
    end loop;  -- I
      BAR(tmp) <= '1';
    end if;
--    begin
--        end generate;
--        end generate;
--      end generate;
----    LUT4_I : LUT4
----      generic map(
----      port map (
--      MUXCY_I : MUXCY
--        port map (
--    end generate;
end imp;
I had read the datasheet of LMB BRAM Interface Controller,however,I could not find imformation in detail about the components in LMB BRAM Interface Controller. Especially,I want to konw the function of the pselect_mask and the LMB address decoding.
Thank you!
  One <= '1';
    generic map (
      C_BAR  => C_BASEADDR,  -- base addr
      C_MASK => C_MASK)      -- mask
    port map (
      A     => LMB_ABus,     -- addr to decode
      CS    => lmb_select,   -- select or not
      Valid => One);
  generic (
  port (
    CS    : out std_logic
  constant Nr      : integer := Nr_Of_Ones(C_MASK); -- 11111 : 5
  constant Use_CIN : boolean := ((Nr mod 4) = 0);   -- Use_CIN = FALSE
begin  -- VHDL_RTL
    tmp   := 0;
    A_Bus <= (others => '0'); -- 0000-0000--0000-0000--0000-0000--0000-0000
    BAR   <= (others => '0'); -- 0000-0000--0000-0000--0000-0000--0000-0000
      if (C_MASK(I) = '1') then -- bit in mask is '1'
        A_Bus(tmp) <= A(I);     -- from addr to decode
        BAR(tmp)   <= C_BAR(I); -- from base addr
        tmp        := tmp + 1;
      end if;
    end loop;  -- I
    if (not Use_CIN) then -- dont care Use_CIN, always equ because both are '1'
      BAR(tmp) <= '1';
      A_Bus(tmp) <= Valid; -- Valid='1'
    end if;
end imp;
    C_MASK :  0000000000000-111 11-00000000000000 = 0x0007C000
    C_BAR  :  0000000000000-010 00-00000000000000 = 0x00020000
      ADDR :  xxxxxxxxxxxxx-010 00-xxxxxxxxxxxxxx : CS='1'
              0000000000000-010 00-00000000000000 = 0x00020000 CS = '1'
              0000000000000-010 00 11111111111111 = 0x00023FFF CS = '1'
                            ****** ADDR=BASE
              0000000000000-010 01 00000000000000 = 0x00024000 CS = '0'
                            ****** ADDR/=BASE
    BASE = 0x0002 0000
    MASK = 0x0007 C000
    ADDR = 0x0002 0000 to
           0x0002 3FFF : CS = '1'
Since this is about an EDK IP core, I believe you'll receive better assistance on EDK board. I'll move it to the EDK board. Thanks.
-Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I think it would be better if you can specify in more details the things you don't understand.
The c_mask handling? or the pselect_mask core? or the VHDL coding of c_mask?
Göran
