running a soft
hello all
i like to running a software in the virtex II pro ff 672 platform, with powerpc  processor
after creating a project with bsb wizard,and adding the path of source file in tab application,
what's the folowing steps to run this code
Depends on how/where you plan on running it.
If the application is built for the BRAM, you could have it be initialized into the BRAM contents and as such it was start as soon as the FPGA image was loaded.
If the application is built to be run out of RAM, you can download it into RAM via XMD with the following command: 'dow <elf_file>'.
