hitpmpm@163.com
sdk 2017.4 "arm-xilinx-eabi-gcc" not found in PATH
hello everyone
when I use the sdk2017.4 on zedboard,I met the following error, I cannot solve it,thanks!
Program "arm-xilinx-eabi-gcc" not found in PATH
sadanan
Hi hitpmpm@163.com,
arm-xilinx-eabi-gcc is the COdeSourcery toolchain, which is no longer available in SDK. You should migrate any old projects to use the new Linaro toolchain (arm-none-eabi-gcc)
sadanan
Hi hitpmpm@163.com,
hitpmpm@163.com
sorry, I am a greenhand to SDK, can you tell  me more details ?
sadanan
In older versions of SDK, codesourcery was the default toolchain, so any projects created in older versions will have a dependency on codesourcery. If you import any such projects to new SDK, you will see this error, since the new SDK only has the Linaro toolchain
If you're seeing this error somewhere else, can you please provide more details
hitpmpm@163.com
I migrate the old version project to the new version, it works! thanks,sir!
    best wishes!
chewenjie27205
I was trying to compile a C program running on the Zybo Linux using 2018.2 SDK, I got an error message when I specified the 2018.2 SDK assembler/compiler/linker as 'arm-xilinx-linux-gnueabi-gcc'. The error is as below:
'Invoking: ARM v7 Linux gcc compiler'
arm-xilinx-gnueabi-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"SDK/common.o" -MMD -MP -MF"SDK/common.d" -MT"SDK/common.o" -o "SDK/common.o" "F:/FPGAs/Zybo/SDK/common.c"
'arm-xilinx-gnueabi-gcc' is not recognized as an internal or external command,
operable program or batch file.
make: *** [SDK/common.o] Error 1
Is it because the new SDK version exclude the 'arm-xilinx-linux-gnueabi-gcc' compiler? How can I fix this problem? Do I have to re-install an older version of SDK to solve this? Thanks.
sadanan
jaume
Hello!
I am new at using Zybo.
I am using SDK 2015.4 and I have the same problem. How should I do in order to use the Linaro toolchain?
