Participant elaa82
sdk compilation error with statement extern
hi friends...
i am getting compilation error for following statement.
//main.c
extern void sub_fun(void);//declared and defined other files(file.h, file.c). And files are added in project folder
int main();
sub_fun();//getting error for this statement
return 0;
Error is "undefined symbol sub_fun". tried with including header "file.h"... But the result is same.
how to fix it?any other way? using edk9.2.4i, virtex4, microblaze
thanks....
Re: sdk compilation error with statement extern
If that is your exact code, you should probably remove the semicolon after int main()...:)
Participant elaa82
no.. no..
it was a typing mistake...
anything else?
Observer pupillo
I tried with edk 12.2. It compiles with no error.
In my sub.c there is just:
void sub_func(void)
In my test.c there is:
extern void sub_func(void);
main(...)
sub_func();
Check that you haven't use static or any strange modifier.
Check that there isn't any prototype of sub_func similar but not identical declared in any .h file
Pupillo
