sending buffers in UART
I have some strange behaviour in uart, in which I need to call
XUartNs550_Recv() routine, even if I just need to do only sending.
I tried to see what causes it in driver, and I noticed the following comment in XUartNs550_SendBuffer (which is called by XUartNs550_Send):
* If interrupts are enabled as indicated by the receive interrupt, then
* enable the transmit interrupt, it is not enabled continuously because
* it causes an interrupt whenever the FIFO is empty
I think maybe this is the key for understand this bug/feature in the UART driver.
1. Does anyone have any idea why it is implemented in such a way, i.e. what's wrong with using tx interrupt whenever FIFO is empty ?
2. If I use XUartNs550_Recv + XUartNs550_Send (instead of waiting for this driver fix ), and there is no bytes received in UART will the sending still function correctly ? Is this the advisable way to work with the UART for now ?
Ran
