Participant cesys
toochain for generating PROM file for AC701
My current tool chain for a Microblaze based ARTIX-7 design.
1. Using Vivado: Generate Bitfile and export it to SDK (File->Export->Export Hardware)
2. Using SDK: Program FPGA and  Run as -> Launch on Hardware (GDB)
Now I've debugged everything and want to program the whole thing in the PROM File of my AC701 evaluation board.
I've added the elf file of the sdk to the vivado project, rebuilt the project and used Hardware manager to programm the SPI Flash of the AC701 board. But the Microblaze software does not run.
Question:
Am I on the right track? Is there a tutorial about "How to bring a working Microblace design into Flash" ?
Thank you for helping!
Re: toochain for generating PROM file for AC701
hi,
there is a procedure to do a flash programming for Serial SPI Flash. refer to http://www.xilinx.com/support/documentation/application_notes/xapp1053.pdf
--hem
Participant cesys
Thank you for your answer.
The documentation you showed me is for ISE 9.2i but i am using Vivado 2015.1
I  think programming the Flash is not the primary problem.
First, I need to produce a bitfile that hast the microblaze code in it.
How can I get such a bitfile using Vivado design flow?
Participant cesys
In LAB 3, the FPGA is programmed using the SDK. Then the elf file is downloaded by using the SDK.
That is exactly how I work up to now.
What I need to know is:
How can I embedd the elf file into the FPGA configuration file so that the bitfile includes the microblaze code and I can use it without SDK.
I tried to add an example elf file (Hello World) to the vivado project but when I load the resulting bitfile into the FPGA it does not output "Hello World" as it does when using the SDK method described above.
