olivetree
tranlation_table.s error in standalone BSP during compilation with ARM compiler 6
I generated a zcu102 board bsp for a bare metal application using XSDK, and then imported it into ARM ds-5 as eventually I will need to use Dstream to debug the application. After setting a serial of includes path in the bsp project settings, the compilation came to a stage to report " invalid reassignment of non-absolute variable 'SECT' in '.set' directive" when it compiles the translate_table.s file under the standalone_v6_4 folder.
Does anyone have an idea about this error?
Olive
ericv
@@olivetree
The ARM tool-chain is not 100% compatible with GCC (Xilinx's SDK).
ARMCC is GCC compatible (it even pre-defines __GNUC__) but the assembler is definitely not.
Here's some options I can think of:
- You'll have to rework the ASM files.
- Assemble the .s files with GCC (caveat: I never tried it) and use them as-is with ARMLINK. ARMASM output files (axf) are ELF files; this is the same object format as the GCC AS.
- You could set your DS5 project path & commands (or a makefile) to use Xilinx's tool-chain directly for the build.
hbucher
@olivetree  Is this a DS-5 or SDK error?
olivetree
The error is generated in DS-5 with the ARM Assembler, but the BSP files I am compiling is generated from SDK. I just imported the BSP files into the DS-5.
Another thing I am not very clear is that I generated standalone bsp for creating bare metal application, but the generated bsp files seem include lots of Linux header files (At least I have to set path to some Linux Include directories to get rid some compilation errors). Do you have a clue why the Linux headers are required by the bare metal bsp?
Olive
hbucher
@olivetree Are you sure DS-5 is supported by the Xilinx SDK?
olivetree
I am just porting the XSDK generated bsp code into DS-5. Xilinx had a document showing how to do it for the Zynq-7000 platform, now I am following the instructions provided in the documen to do the same thing for the ZCU102 board (https://www.xilinx.com/support/documentation/application_notes/xapp1185-Zynq-software-development-with-DS-5.pdf). I think it doable, but I am just stuck at this translation_table.s file. I think I knew what the problem is now, but I still do not a solution for it. The problem is that the translate_table.s is generated for GNU ARM assembler, but I am using ARM assembler who seems not be able to recognize some of the directives created for GNU arm assembler. Any suggestions are appreciated!
Olive
ericv
@@olivetree
olivetree
@ericv wrote:
@@olivetree
Thanks ericv for your suggestions! The problem is solved by revising some of the directives in the .S file.
