hojze
urgent .Build system image fail
I'm sort of new to zynq and linux. while I followed the instruction of UG 1144 to build system image I got the error message below. anyone can help me , thanks in advanced.
root@jvr:/home/jr/project/p4/system1# petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[ERROR] make[4]: *** [lib/asm-offsets.s] Error 1
[ERROR] make[3]: *** [prepare0] Error 2
[ERROR] make[2]: *** [sub-make] Error 2
[ERROR] make[1]: *** [/home/jr/project/p4/system1/build/linux/u-boot/u-boot-plnx/u-boot] Error 2
ERROR: Failed to build linux
P.S
1) I generate the hdf file from vivado 2014.4 on windows 7 32bit
2) My ubuntu edition is 14.04 64bit
3) I can't install the lib  ia32gcc1
