Advisor ronnywebers
Advisor
why are there 'canonical definitions' in xparameters_ps.h and xparameters.h
I'm wondering what exactly is meant with a 'canonical definition', and why one uses it.
For example from xparameters_ps.h:
/* Canonical definitions for Interrupts  */
#define XPAR_XUARTPS_0_INTR		XPS_UART0_INT_ID
#define XPAR_XUARTPS_1_INTR		XPS_UART1_INT_ID
#define XPS_UART1_INT_ID		82U
why would one use 'XPAR_XUARTPS_1_INTR' and not just directly 'XPS_UART1_INT_ID'?
Re: why are there 'canonical definitions' in xparameters_ps.h and xparameters.h
A canconical definition relies on the IP name for the xparameters entry where a non-canconical definition relies on the instantiated IP name. So if a hardware designer changes the instantiated IP's name, then the non-canconical name would change.
I'm not sure if it is still the case, but at one time the down fall of using a canconical definition, when two or more of the same IPs are in the design, is that the order can change.
For example, if your uarts are at base addresses 0x80000000 XUARTPS_0 and 0x90000000 for XUARTPS_1, some design changes could cause the canconical definition of XUARTPS_0 to be at 0x90000000. I doubt this ever occurs when using PS peripherals but there was a time when it could occur with multiple PL peripherals.
