Observer saberiandy
why can we configure ps_ddr's ports in the vivado ps7 block design?
It's very strange when i create a ps7 block design in vivada.
What can we do with these ports in the wrapper file?
Should I set the pins for these ports in the xdc file?
inout [14:0]DDR_addr;
inout [2:0]DDR_ba;
inout DDR_cas_n;
inout DDR_ck_n;
inout DDR_ck_p;
inout DDR_cke;
inout DDR_cs_n;
inout [3:0]DDR_dm;
inout [31:0]DDR_dq;
inout [3:0]DDR_dqs_n;
inout [3:0]DDR_dqs_p;
inout DDR_odt;
inout DDR_ras_n;
inout DDR_reset_n;
inout DDR_we_n;
Thanks all
Re: why can we configure ps_ddr's ports in the vivado ps7 block design?
When you click on the BD of the processing system and click on generate output products, this will generate a XDC file with the pin mappings of this DDR. I am attaching one xdc that i generated as an example.
--Hem
--Hem
Observer saberiandy
thanks for your reply!
I find this xdc file in my project folder now....and customizing ip will change it but it's strange that I can't find the xdc in my vivado(simply don't know how to open it)...
Glad to see that you are able to see the xdc. Can you use file --> open file --> point to xdc that is generated?
--Hem
