why fopen command not work in SDK?
Hi,fopen command not work in SDK? I have searched everywhere but the exact answer is not available and the file is set in standalone mode and is also set in the system. i have also set xilffs in system.mss Please help
thanks
mohit
Re: why fopen command not work in SDK?
Hi mohit@98 ,
it is not possible to open a file in desktop where as your code runs on zynq board. when fopen command executed then prossor looks for the file in its memory not on the desktop. what you can do is, copy the file into sd card and kept it in sd slot of zynq board and initilize it and use fopen to read the file from sd card.
Best Regards,
Srikanth
how can i want to read file through Zybo Z10 board
what error are you seeing?
it can give unwated results and check across fopen the result could be zero. means fopen could not read file which is on desktop. why this problem comes can't understand? please help sir.
thanks
mohit
Scholar u4223374
Just clarify this for me ... you're using fopen in SDK (which is generating code that runs on the Zybo) and trying to open a file that's on your desktop PC?
yes sir correct.
Still working on Fopen not get solution.
Hi mohit@98 ,
Best Regards,
Srikanth
thankyou sir for help.
mohit
