xiic_low_level_eeprom_example
I want to use the xiic_low_level_eeprom_example.c which is in the foder of the iic_v2_04_a\examples to test the IIC.but I find that it is still in the follow statement:
while ((StatusReg & XIIC_SR_BUS_BUSY_MASK) == 0) {
StatusReg = XIic_ReadReg(BaseAddress,
XIIC_SR_REG_OFFSET);
My  development board is SP605,and I have modify the macro EEPROM_ADDRESS as 0x54,and I don't want to use the intc,but I test the SDA and SCL pin on the EEPROM(U4),I find they don't have any change when I excute the start and the send function .
Hi, I also have the same your problem !
It hangs in while loop
while ((TransmitComplete) || (XIic_IsIicBusy(&IicInstance) == TRUE))
But I don't know why ?
If you had sovle this problem, Please help me !!!!!!!!!
thanks you very much !
