xilmfs missing from supported libraries in BSP (Vitis 2019.2)
I am migrating my project (on a PC with a Windows operating system) from 2018.2 tools to 2019.2.
In Xilinx SDK 2018.2 I selected xilmfs ver 2.3 (Xilinx Memory File System) in the Board Support Package Settings under Overview>>>Supported Libraries
However in Vitis 2019.2, xilmfs is not listed under the supported libraries in the Board Support Package Settings.
Why is xilmfs not listed and what should I do about it?
xilmfs is depecrated starting from 2019.1
Please use xilffs instead.
See commit here
https://github.com/Xilinx/embeddedsw/commit/c470ed880028fb083fffa1a271ec2ee7797e0feb#diff-b3a135821a233a0fb67ff810b1298c23
See commit here
Alternatively, as a temporary solution.
I just copied these files from the BSP in my SDK 2018.2 project in with my application source code files in my Vitis 2019.2 project.  And that worked fine for me and I didn't have to re-write my code.
  • mfs_config.h
  • mfs_filesys_util.c
  • mfs_filesys.c
  • xilmfs.h
Hi @jovitac , Thanks for your reply.
My current design uses xilffs for an SD-Card interface and xilmfs for writing/reading files to RAM.
Looking at UG1032 October 30, 2019, it instructs when generating the xilffs library in the BSP/Platform: to set fs_interface = 1 for a SD-Card and fs_interface = 2 for RAM
What do I do if I want both SD-Card and RAM?
>>>EDIT 28 JAN 2020>>>  Created seperate post for this question Here
Hello everyone
i want mfs_config.h file can you please send me this file.
Aishwarya
Hi aishwaryaakul@ These are the files that I copied from the BSP that I generated in my SDK 2018.2 project
