Visitor asayans001
xps dont open datasheet
I have Xilinx ISE design suite 12.3 and allready installed 13.4 . I have this problem in earlier version and it allready persist. when i whant to se and IP core datasheet, i go to that IP righ click on int and select "View PDF datasheet", but nothing happens.
Someone has this problem? or know hot to solve it?
thank you in advantege.
Re: xps dont open datasheet
Yes there was a known issue which was fixed in latest versions.
All data sheets for IP available in an ISE installation can be found at: $XILINX/ip/xilinx
In this location, you will find folders for categories of IP.  For example, if you are looking for the PDF for the MAC FIR core, go to the following path:
 $XILINX/coregen/ip/xilinx/dsp/com/xilinx/ip/mac_fir_v5_0
Hope this helps.
Sikta
Hope this helps.
Sikta
Visitor asayans001
Thank you, is not the specific places i have at
$XILINX/EDK/hw/XilinxProcessorIPLib/pcores/*****/doc
but your answer has been so usefull.
