Voyager
Voyager
xsa file gen : vivado 2020
I have project where Block diagram consist of PS IP and (HDMI and VPHY) are instatiated outside the block digram in a file. Then XSA file is generated and exported to VITIS. But this file through an error with out description.
May I know what could be wrong.
NOTE: it works when HDMI IP is inside the block diagram where PS IP is present.
Thank you
Kind regards
The XSA will only contain the cell (IP) info for IP in the Block Design. So, if you have added IP outside of the BD then this will not be reflected in the xsa.
The XSA is used to create the BSP in Vitis (and the devicetree in uboot/linux). So, if you have the IP outside the BD, then these drivers will not be added to the BSP
Can you share the XSA? You shouldn't see an error. Just the drivers will not be populated.
Voyager
Voyager
hi,
Please find the xsa file in the attachment.
Please extract the file from .zip
thank you for help
Voyager
Voyager
hi @stephenm
Is there any update for me regardign the error.
thank you
Voyager
Voyager
I am still waiting for the feedback or at lease a suggestion.
thank you
HI @msh
The XSA looks to be missing the block design content. Is there more information, which would account for the error. Is there more information on the steps used to create this? Is the Vivado project available?
Voyager
Voyager
@marcb
Could you please file share request.
thank you.
I can see your issue with your XSA file. Can you pass on the project? I can take a look. you can send send me a email if you like
Voyager
Voyager
Hi @stephenm @marcb
here is the project in the attachment.
Please read readme.txt file in the zip which describes the project and how to create the project.
looking forward for your reply.
thank you
Voyager
Voyager
@stephenm  @marcb
Is there any update for me ?
Hi @msh
Currently we have reported the issue with development, and this is being investigated. Once a workaround is found, it will be posted.
