xsdbserver listen to incoming commands
Hello
my application requires MATLAB to send commands to xsdb console continuously.
this was done initially using
xsct.bat <file_name>.tcl
while this works, there are limitations due to MATLAB which requires us to send COMMANDS directly to xsdb instead of sourcing tcl files.
After some study, I think maybe xsdbserver could be used, which constantly listens to commands from MATLAB. So I first set up xsdbserver in xsct console using the following command
 xsdbserver start -host localhost -port 2000
Then I set up MATLAB TCP IP object and send text strings
t = tcpip('127.0.0.1', 2000, 'NetworkRole', 'client')
fopen(t)
fprintf(t,'%s','connect')
fprintf(t,'%s','targets 6')
After checking, I don't think that these commands were sent properly. 'targets 6' was not set up properly.
Can you help me point out what is wrong?
Thank you
Re: xsdbserver listen to incoming commands
So I restarted xsct. restarted xsdbserver.
It is working now.
These codes work in MATLAB with xsdb.
fopen(t)
fprintf(t,'%s\n\r','connect')
fprintf(t,'%s\n\r','targets 9')
fprintf(t,'%s\n\r','version')
For every command, xsdbserver server sends a reply back in the format "okay <result>" or "error <msg>". Have you checked if you're receiving any such replies?
It is working now.
fopen(t)
