xst.exe not working
Hi all,
I am experiencing the problem on xst.exe stopped working. It is strange because my last run yesterday goes fine and i haven't changed anything since then. Can anyone provide any help? Thanks.
T
Re: xst.exe not working
Did you add any IP's to the design?
Which version of ISE are you using? In the crash message do you see any references to libSecurity_FNP.dll in details tab?
There is known issue with ISE 14.6 and 14.7, check this article http://www.xilinx.com/support/answers/59851.html
Deepika.
Deepika.
Thanks for your reply. Yes I added an IP when designing. Basically I am migrating a system from spartan to zynq. I made the whole system as a netlist (.ngc) and included it as an IP. The whole system also contains some ngc and xco files from core generator and I have included all of them in the netlist file of my IP.
I am using Planahead 14.7 but haven't seen any .dll mesage. Could you please provide more detail on how to solve this? Thank you.
T
As a follow up, there is a licensed ip in my design which is the video-scaler. the xst stops working problem starts to happen when I add the video_scale.ngc file in the netlist folder of planahead. I am using an evaluated license to generate this video scaler ip core from the ise corgen. Is there any restriction of transforming this ip from ise to planahead? Your help is most appreciated. Thank you very much.
T
There is a patch file attached to the article http://www.xilinx.com/support/answers/59851.html
Install the patch by following the instructions in readme.txt and see if that helps.
Deepika.
Deepika.
Hi @psun.tom
Did that work?
Deepika.
Deepika.
