zc702 pin out question
so i notice for zc702 DDR, there is no constraint for ddr_dqs_n/p or the ddr_we_n after i generate the PS project.  is it just doesn't use it or its missing?  if so anyone know the pin io standard and location for  dqs and we_n  for zc702  thanks
Re: zc702 pin out question
you can check the master XDC for the mig ddr signals and the IO standards assigned. here is the link to hte master XDC for zc702 - link
Anirudh
There is constraint for ddr_dqs_n/p by default when you add zynq IP in your design.  You can verify the relevant constraint file for the processing system IP in Libraries tab -> <block_design_name> -> processing_system_0.xdc. See the attached figure.
Refer to http://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf page 17 for DDR component pin constraints.
Praveen
