zynq SDK2017.4 and 2018.2 library code debug problem
   when I use SDK 2017.4, even just used the template program of helloword or hellofreertos, the start code, libxil or freertos lib code will display assembry code when I debug step in, while it run correct. and my application code could debug and display normal.(vivode use 2017.4 run on win7)
  So I use SDK2018.2, debug step in lib code, it could display lib source, but cursor maybe run out-of-order, just like lib code optimize, while result is correct.
 But SDK2015.2 hasn't above problem. How to resolve it? (Just like sometime debug kernel code, how to configuration)?
Re: zynq SDK2017.4 and 2018.2 library code debug problem
Make sure that in BSP settings in extra_compiler_flags you have "-g" to include the debug symbols and -O0 to remove the optimizations which can affect single stepping (that should overrun the default -O2 flag in 2018.2).
--Kim
